Palstar Node-Red Flows, LA-1K Amp and HF-Auto Tuner
Alan
Alan Member ✭✭✭✭
Node-Red based flows for the Palstar LA-1K amp and the HF-Auto Tuner.
Download here:
Dave, WO2X contributed to the LA-1K Flow.
The LA-1K Flow uses Frequency from the Flex via the WO2X API or FRStack, or from N1MM to provide a CAT Frequency Follow to the LA-1K. User needs to select one of the available sources.
The HF-Auto requires the use of W1TRs HF-Auto Application and a Frequency source, such as FRStack or N1MM.
Here is a screenshot of both flows on one dashboard.
Alan. WA9WUD
