Panadapter and waterfall frozen on new windows 10 laptop.
I have searched and not found a how to post pictures to this forum. Following tims article on a picture is worth a thousands words, But does not describe the process. Since I do not see an attachment tab anywhere..... I assume I upload my picture to online hosting site and paste the link here.
Please share the post that I could not find, so I get onto solve the windows 10 issue.
Thanks in advance
Shawn
Ve3Xyy
There is a paper clip at the bottom of the bounding box where one types in the comments.
One can attach a JPG / PNG image file to post.
Thanks for the answer Tim. Inside the bottom left of the bound box I do not have an option to post images thru a url when I am logged into the flex community, however if I log out and revisit this post there is a option then to up load images thru a insert media "url" . I'm wondering if I don't have privileges yet, to post images yet. Can someone confirm or deny this is the case. Im using chrome as the browser.
Copy and paste this link and you will see I have no options to include attachments.
https://ibb.co/b1QVy04
It seems silly I would have to put a ticket in to request something that can be solved by the good users of the FLEX COMMUNITY.
Shawn0 -
@ShawnQuinn Correct. You need more Community points before you can post images (this is a mechanism to prevent spamming).
-1 -
I have a 6400m running 3.1.12. On my windows 7 PC everything works as it should. Just received new windows 10 Laptop, this is when the problems started.
Problem is the panadapter and waterfall do nothing. They display what ever is going on when first launched, then freeze. The slice A window cuts off most of the frequency display. I can transmit, tune, move slice around everything else appears to work.
Since I can not post pics to this forum yet. Please copy and paste the link below to see image of above.
https://ibb.co/FVpkKmj
Here is the display windows settings. Please copy and paste the link below to see image.
https://ibb.co/v4QkQR5
Here is a close up of slice A window. Please copy and paste the link below to see image.
https://ibb.co/0hdzRf5
Here is a copy of Network Diagnostics. Please copy and paste the link below to see image.
https://ibb.co/gPSWJGN
The new windows 10 laptop is connected directed to 6400m by cat 6 (non-shielded). Cable is GOOD.
Here are the window10 and Laptop stats. Windows 10 is up to date. Please copy and paste the link below to see image.
https://ibb.co/NNdzqCr
https://ibb.co/ZJ3h6pW
https://ibb.co/nm87w6n
I can show a list of drivers from the cmd window, however the list is very long, would be a lot of screen shots. If there is any particular driver that needs to be shown let me know and I will capture and post links to them.
I apologize for the long post with all the copy and paste links, however I don't a see I way to provide the information required.
Thanks in advance
Shawn
ve3xyy0 -
Here is my Cat connections currently. Please copy and paste the link below to see image.
https://ibb.co/VTX5f1J
Shawn
ve3xyy0 -
All fixed, turns out the PC graphics adapter/driver combo has a defect. For a temporary workaround solution, the Hardware acceleration has been disabled. Tim Ellison provided me with a line of text to add to the Registry.
SmartSDR 3.1.12, Works as it should now. FlexRadio customer service is awesome!
Special thanks to Tim Ellison for his quick attention to this matter.
Merry Christmas all.
Shawn
VE3XYY0 -
I am having the same problem after installing on a new WIN10home computer. What was the solution??0
Hi Roger
I submitted a Ticket, the reply Tim provided, is a work around till intel can provide a fix. My Smartsdr 3.1.12 waterfall and panadapter work as they should now.
"If so that graphics adapter/driver combo has a defect for the GPU implementation and a temporary workaround solution The bug is in the Intel Iris Xe hardware acceleration implementation. Hardware acceleration has to be disabled.
Below are the registry commands for disabling hardware acceleration and re-enabling when a fix is available.
Copy and paste the following into the Command Prompt with administrator rights and press the Enter/Return key.
reg add HKCU\SOFTWARE\Microsoft\Avalon.Graphics /v DisableHWAcceleration /t REG_DWORD /d 1
To re-enable:
reg delete HKCU\SOFTWARE\Microsoft\Avalon.Graphics /v DisableHWAcceleration
I did try the lasted drivers but only worked for a short time, so went back to the registry change above. Works again as it should.
SHawn
ve3xyy
If the new drivers worked only temporarily, you may find that that an OEM maintenance utility rolled back the driver to an older version. I had to disable HPs driver update utility auto update feature, as it kept rolling back the new Intel driver. This was because the Intel Driver was newer than the one available on HPs website.
After disabling the HP driver update utility and reinstalling the latest Intel Driver the fix became permanent.
Ted WR4T
The registry command fix the issue on my ACER Swift I7 with Intel Xe graphics. :-)
Thanks!
Alessandro i2sva
- 715 The Flea Market
- 218 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 994 Genius Products
- 363 Tuner Genius XL
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
