SmartLink has quit auto-connecting on my 6600M and on SmartSDR on my PC
* I've always had to use Port Forwarding with the ADSL assess, but previously with no Auto-Connect issues.
* Powering down the 6600M or Exiting SmartSDR now requires login.
* Auto Connect SmartLink is checked in Settings for SDR, CAT, and DAX.
* SmartLink Test is passed when logged in.
* Once logged into the 6600M and SmartSDR, remote operation works as usual.
* Oddly, it does auto-connect for DAX only.
* Failure to auto-connect also occurs at remote locations.
* This issue started recently with no known changes to my LAN setup.
I've read about "expired security tokens" on the server so tried changing the registered email address on SmartLink. Then tried changing it back. Then tried changing my password for the original email address (knowing that shouldn't work). I've also lowered the FireWall Security Level with no luck.
These symptoms indicate to me that something has changed at the server.
I'm a moderately sophisticated with networks.
Thoughts?
  • G3VM
    I also have the same problem, was working fine until this afternoon
