Node-Red on Unbuntu 20.04 (64 bit)
Mick  W8BE
Mick W8BE Member ✭✭✭
edited November 2020 in Third-Party Software
I am working on migrating my node red flows to unbuntu 20.04 server edition in order to take advantage of the 64 bit OS. I wanted to pass on info on what I had to do to get dot net and FRStack to load...
Here is what I had to load to get dotnet / FRStack up and running:
I downloaded the following file and ftp'd over to my Pi.
dotnet-sdk-3.1.109-linux-arm64.tar
Then follow Mark's directions:
sudo mkdir -p /opt/dotnet
sudo tar zxf dotnet-sdk-3.1.109-linux-arm64.tar.gz -C /opt/dotnet
sudo ln -s /opt/dotnet/dotnet /usr/bin
I just got it up and see the process:
/usr/bin/dotnet FRStackWebApi.dll --urls http://*:5025
I have to still enable the flows and test it out. Hoping that I am past the hard part.
Here is what I have noticed on 64 OS vs 32 bit OS. on the 32 bit OS, memory load is stingy. Using a 2Gb Pi I run about 25% of available ram. On the 64 bit it pretty much doubles the memory load. However the the cpu ticks are reduced. I never thought about that in those terms before. I guess it makes sense.
I will report back probably tomorrow to advise if the flows work as advertised.
Mick
  • Mick  W8BE
    Ok so I could not wait...Had to try it out....and...it works....
    As you can see cpu ticks are low but ram usage is up...
