SPE Amp Input > Flex TX Antenna Follow Node-Red Flow
Alan
Dave, K9UK, asked if I could add to the MKCM SPE amp flow to have the Flex TX Antenna (ANT1 or ANT2) command the SPE amp to switch the Input (1 or 2).
If you select Flex TX Ant1, Node-Red commands the SPE amp to use Input 1
If you select Flex TX Ant2, Node-Red commands the SPE amp to use Input 2.
I included a button on the SPE Amp Dashboard to turn the "Flex Antenna Follow" on/off.
I am not an SPE Amp owner/operator, but am told this will help with SO2R and Receive Antenna operations.
The flow is available on the Ham Radio Node-Red Forum;
Alan
WA9WUD
- 407 Community Topics
- 704 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
