PowerGenius 2 radio
Jean Drolet
i have 2 radio 1 Flex6600m ans 1 Anan 7000DLE MKII ..
It's possible connect flex6000 to amplifier by Lan to ant 1 and connect Anan by RCA to ant 1 also.
i try but doesen't work
thank 73'
In the Flex Radio tab of PG-XL delete the Anan entry on the B side but leave it set for RCA.
You need to connect the Anan using a serial cable from the PC to the amp RS232 in for the B side. In the Anan software select the com port of the PC that is connected to the amp. In the PG-XL control panel under CAT/CI-V set the B side to Kenwood. Make sure the baud rate for the CAT/CI-V tab on B side matches the CAT setup in the Anan software.
- 683 The Flea Market
