DAX and PROC on P/CW
More like question than discussion, not sure the difference anyway.
While trying so set up some memories to switch between FT8 and SSB in FRStack, I selected the RTTY mic profile which turned on DAX and turned off PROC. When I try to switch back to any of the voice mic profiles, Dax is off, Burt he PROC won’t turn on. Sort of a grayed out blue.
Hi John, are you in DIGU or DIGL mode? If so, I think that disables the compressor. Switch to USB or LSB an see if that makes a difference.
Len, KD0RC
So, was apparently a temporary fault. Restarted Radio and SmartSDR. I set up a MIC profile with DAX enabled and another one with PROC enabled. Switching profiles changes the setting as I expected. Changing mode on the flag doesn't seem to affect the P/CW panel. More experimentation is in order.
Hi John, glad that was it. When I change modes from the flag, my profiles do change. I am not sure why it is not working for you. May be time for a help desk ticket.
Len
