No Output after Inactivity
Hi.
Have an issue with running ft8.
My setting: Flex 6600m, windows 10, DAX v3.1.12, CAT v3.1.12, but not running the SMARTSDR interface (just using radio), Slice master v0.10.7c, and jtdx 2.2.0-152.
After starting up all works great, but if i leave the system inactive for some time time the tx audio is not streaming any audio from jtdx to radio.
This is not happening on any other radios am using.
And computer is put to never sleep and i have looked "all places" in powermanagement to find this problem....
Regards
Bjorn / La5vsa
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    I had more or less the same issue with a 6600m and xDAX / xCAT on a Mac. I would let the radio sit sometimes for a few hours, sometimes overnight, and in my case, there was a disconnect when I checked. Turns out it was my network. An intermediate switch must have been misbehaving. When I switched it out (went directly to the main switch), everything started to work fine - no more issues with no connection or connection issues.
