No audio on 80 meters
AA1OU
Member ✭
https://www.facebook.com/photo?fbid=10158721770850135&set=gm.10158246367721321
I've posted this on Facebook, but I'm posting this here as well looking for help.
Can someone please help me figure out what I'm doing wrong. I'm running SmartSDR v3.1.12. I have a 6400. I have no sound on 80 meters (shown). I hear audio on all other bands except 80 meters. Additionally, when I transmit, no power goes out. If I tune, then things appear to work correctly.
There are two volume controls. One on the Slice and a master volume. Make sure that both are turned up. And there is a slice MUTE control too (the small speaker icon). Make sure that is not enabled.
Thank you. That has been resolved. Still no power on transmit.0
In your "setting Menu" drop down look at the "TX Band settings", make sure that that boxes like PTT Inhibit are NOT checked. That maybe causing your no TX problem. Also make sure the power is not set to zero.
Gayle K0FLY
> Gayle K0FLY
No and no. :(0
