Unable to get PC microphone to work
Trying to get a PC in another room to remote to my 6400. Everything seems to work OK from the remote PC except TX audio. The PC shows the mike is functioning but no TX audio reaches the radio. Does anyone have a list of necessary settings for remote operation?
Tonno..that's exactly the problem you "nailed it". Thank you so much. I went thru all the mic profiles and shut off DAX for those that had DAX switched on.. There were just a few. Thanks so much I can finally put this to bed.
73 Al, W1JHU
Hi Al... how is the mike connected to the PC? Is it directly plugged in via Mic port, USB? Or is it Bluetooth? If the latter, I don't believe it will work (at least it didn't for me the last time I tried).
If the former, make sure you've selected PC Audio (top right corner of SmartSDR screen) and make sure you have the PC input selected on the MIC option on the P/CW panel (right side of SmartSDR).
Hi Al, in the P/CW window on the right side of SmartSDR, use the dropdown box to change from MIC to PC. I think that will solve your problem. If you have already done that, then you may be having problems with your default mic setting in Windows.
Len, KD0RC
The Mic is directly plugged into the Mic port and PC Audio as selected (top right corner of SmartSDR screen). Additionally, in the PC/CW window PC is selected. I believe the problem may have something with the TX DAX settings in the windows sound setup. Any suggestions as to what it should be set at? In the Windows 10 sound settings the mic level shows it's working when I speak into the mic but it doesn't show any audio on the transmitter.
Hmmmm.... I may not be understanding what you have set up, but the DAX settings should affect mic input to the transmitter. The DAX settings are for feeding audio OUT to other programs, etc. on your PC.
What's the MIC level set to?
Don
Don..thanks again for your response. This remote stuff is far to complicated for me so I'm going to give up on it for now. Maybe I can find someone to come to my QTH or maybe someone to do a Teamviewer session with me. Thanks for you suggestions and help. Best 73 and be safe.
Al
W1JHU
Hi Al, Just to be sure - you are not using a Maestro, right? On that assumption, in SmartSDR, you will see in the pic below that MIC is set. This will take audio from the MIC jack on the back of the rig. If you have your laptop in another room, use the dropdown and change from MIC to PC. Now audio will come from the mic on the PC. The receive audio is directed by the "PC Audio" control in the upper right hand corner of SmartSDR, and it sounds like you already have that set properly. Note that "PC Audio" does not change the mic at all, it is strictly a RX control.
I hope that helps.
Len, KD0RC
Len TNX for your reply. I have the settings as you describe. Here's where I stand now. I'm able to get TX audio to the radio if I use VOX. But, I can't TX audio to the radio when I activate MOX. Any ideas? Do I need another PTT command other than "MOX"?
Al, W1JHU
Hi Al, it sounds like you are almost there. You may have a TX Profile that has the PTT Inhibit box checked for the band of interest. If this is the issue, be sure to uncheck it for all bands, then save your TX Profile.
Len
Len I set the settings the same as yours and did not correct the situation.
If I set the rig to use VOX mic audio is OK but does not TX audio in the MOX mode.
Got it working!!! TNX FOR ALL YOUR HELP
Al, W1JHU
Excellent! what was the solution?
Len
When I operate SSB I use the "Default PR781 ESSB 3_2K" MIC profile. When I switched to the "Default" MIC profile all worked OK with the MOX button. Even worked fine in remote with another PC. Don't know why it acts that way with "Default PR781 ESSB 3_2K" MIC profile. Thanks again
Al
W1JHU
CLOSED!! TNX to all..
oh, it looks like you simply had DAX activated (switched ON) in your initial MIC profile and when you changed to Default MIC profile it just happened to have DAX switched OFF (setting is based on profile) and that is why your PC MIC started to work. Just read all this now and quite amazed nobody told you to simply switch the DAX off because PC MIC is NOT working when DAX is ON. You may confirm this was the case. You can pushing DAX button and turn it blue and you see your MIC is not working again...
ES5TV
Al
W1JHU
Well, I just tried to suggest you why it acts that way:) Try to change the profiles and note if DAX is ON or OFF (DAX button blue or grey).
ES5TV
…0
