Python code for FlexControl available
orthoclase
Member ✭
in FlexControl
Yesterday I wrote some Python 3 code to work with my FlexControl. It's a single class that reads event codes from the device, and also controls its lights. The class simply runs an event loop to read the codes and print them as they are received. It is intended to be used as part of a larger program that can process the codes to make useful things happen.
I use Linux and wrote it to run on that OS. But Python is cross-platform, and the code should work on other OSes given the proper USB port to use. Also, it needs some polishing up in the form of error handling for port accesses, and the like. But it's fully functional in its present form.
I've posted the module for downloading on my Web site at https://kc7mm.com/wiki/doku.php?id=programs
Russ, KC7MM
Russ, KC7MM
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
