AG 8x2 configuration
I am trying to setup AG 8x2 for 3 antenna's.
Here is my setup
Output 1 - 6m monoband
Output 3 - Steppir
Output 4 - 80/160m Vertical.
My vertical has 2 relays at the base to switch coil between 80 to 160m.
I used Array Solution box before and it was working fine. Now I setup AG 8x2 and cannot figure out how to setup OM box with 2 configuration and 1 output.
Here is my setup
No problem with output 1 and 3, i have to figure out Output 4. Here is the output 4 with 2 Bands
I need the following configuration,
For 80m, I need
But for 160m , I need
How this can be done for a single output?
Sergey, KN7K
  • Sergey KN7K
    Sergey KN7K Member ✭✭✭
    Answer ✓
    Well, read the (...) manual - sometimes it helps :)
    I figured it out, I had to add another line for OM module
    For 80m
    For 160m
    Pretty cool
    Sergey, KN7K
