FT8 filter edge "noise"
Rich McCabe
Rich McCabe Member ✭✭✭
edited June 2020 in Third-Party Software
So have always wondered what this is. If I have my DIGU filter set to 3khz I see noise at the edge of the filter (see arrows).  If I drag my filter out a little wider that disappears.
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    open your receive filter more, I run mine at 0 to  5K and that noise you see goes away.
  • Rich McCabe
    Yes that is what I am doing but I do not like to run excessive filter width. Should not be there. Was just wondering why.
  • Larry _ NY8T
    Maybe filter skirts, any radio I use for Ft-8 does the same thing if I don't open the receive band pass more than what i want to see on the wsjt-x waterfall.
  • Rich McCabe
    OK good info Larry. Thanks
    It is the filter roll-off at the band edges.  The DIGx filters don't need to be brickwall on the edges so by doing this we reduce signal propagation delay (latency) through the receive filter.
    Making the filter a little wider at the high end will not affect FT8 reception
  • Rich McCabe
    More good info.  Thanks Mayor.
  • Patrick
    Patrick Member ✭✭✭
    One more thing to check is to go into wsjt-x config to advanced under miscellaneous see what receiver bandwidth is and set it to 3000 and your digiu to 3000.  I think the default is 2.5k in wsjt-x.  Also set the bin/pixel to what is best for your display. In my case it is 2. These 2 settings gets it all matched to 3k RX BW and no noise bar.
