CW Sidetone Adjust
len
len Member ✭✭
How can I change the sidetone frequency?
    Hi Len, if you are using SmartSDR, put the radio into CW mode, then open the CW panel. It has a control for pitch. 73, Len, KD0RC
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    it's on the CW transmit control panel. It is labeled "Pitch". See the bottom right corner of the screen: <<< right here!
  • Andreas Junge
    Andreas Junge Member ✭✭
    There is a pitch entry field :
    I hope this helps.
    73, Andreas, N6NU
  • Neil D Friedman N3DF
    On the 6400M/6600M, put the radio in CW and press the Mic/Speed/Power button to reveal the pitch control.
  • len
    len Member ✭✭
    Thank you! I needed to be in CW mode to get the pitch control to show up.
