NO RX EQ ON SLICE B
FISHULA X
WHEN I OPEN A NEW SLICE B ON THE UPPER LEFT HAND CORNER SO I CAN LISTEN TO 2 DIFFERENT FREQS AT ONCE IN THE SAME PAN ADAPTOR, ONE SIDE SLICE THE A SIDE IS MUCH LOUDER THAN SLICE B?? AS I PUT ONE FREQ ON THE LEFT CHANNEL AND ONE ON THE RIGHT. SLICE B DOES NOT EQ THE RX??? I HAVE READ IN THE PAST THE WAY AROUND THIS IS TO SWITCH THE MODE FROM LSB TO USB AND BACK TO LSB ON SLICE B AND THEN YES IT WORKS. WHY DO WE HAVE TO DO THIS EXTRA STEP.?? I HAD NO ISSUES WITH THE OLD SOFTWARE UNTIL I ADDED 3.1.12. ANYONE HAVE THIS ISSUE?. PLEASE FLEX LOOKS LIKE WE NEED TO FIX THIS ISSUE.....SORRY FOR THE CAPS MY KEYBOARD IS SCREWY.. THANKS.
I have the very same fault I have just posted the below on an older thread a few minutes ago and have just stumbled on this one now as I continued to search the Flex threads....I don't recall having this issue before upgrading to 3.1.12
Hi Flex Community & Support.
I have a 6600 running v3.1.12 I have this problem where I have noticed Slice B , C, D have a dulled down sound to the receive audio and the RX EQ is not working on SmartSDR & Maestro. I was going to log an incident with the Flex Support help desk tomorrow and thought I would search the Flex community site first to see if other operators are experiencing this same fault and found this post on the same subject.
Have the Flex developers got to the bottom of this fault, is it hardware or software and what is the permanent fix ?
As I have only just found this post I have tried switching mode and back again on Slice B and can confirm the audio dullness has cleared and the RX EQ is now working, yet to try other slices on other bands as I had the problem on all Slice's except Slice A on all bands. Is the work around persistent or will you have to do this mode work around every time you active a second to fourth Slice ?
Thanks, what a great community :-)
Regards
Paul M0AIA
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
