Bands switching audio
Sergey KN7K
Member ✭✭✭
It is probably a silly question, but could someone explain me the logic of audio level changes when switching from active Slice A to Slice B.
Slice B has audio muted, but I am puzzled why would audio on slice A drops.
Both Slices use different antennas.
https://drive.google.com/open?id=1XsPuJv3rxoSld0qPNZjaYYefbPsUa43f
Sergey
Sergey
The signal levels are not the same between both panadapter. The louder panadapter (top) has a higher noise floor and will have a louder volume and a consequence of that.0
Hi Sergey, you have a different RX EQ profile for each receiver. Make them the same, and you will not see this effect.
Len, KD0RC
Better yet, use the AGC-T as this is that it is for. The AGC-T is too high on the top panadapter so it is amplifying band noise.0
Tim, I understand the noise level is different between 2 bands.
But I am not listening 6m on that video, as you see on the video Speaker is Muted on 6m.
So, expect to hear audio on Slice A without level changed. Am I wrong?
The reason I switch between them is to have control of the buttons and sliders for Bandwidth and was puzzled by audio effect.
Thank you
Sergey, KN7K0 -
Sergey, I notice in the video that your RX EQ settiings change when you select the 6M RX. Could that be the issue? Set the 6M RX EQ the same as the 160M RX EQ and see if that makes a difference.
Len
Thank you Len for reply.
I am trying to understand why it is relevant if audio from Slice B is muted.
This is my confusion point.
Sergey, KN7K0 -
Yep, I understand. What I am suggesting is to set the RX EQ the same, and see if the issue clears. If it does, it may indicate a bug in SmartSDR where it is using the wrong RX EQ. If it does not clear it up, there may be something else like AGC-T or the ant preamp at play. Which radio do you have? I have a 6400, so I cannot adequately experiment with this because I have only one Spectral Capture Unit.
Len
i have 66000
