FRstack Feature Request - Timer
Mike VE3CKO
Member ✭✭✭
I would like to see a timer feature that would allow memories stored to be automatically recalled at a certain time/day. Let's call it Timer Profile. Check box options Daily, Weekdays, Weekends, Mon, Tues, Wed, Thurs, Fri, Sat, Sun and of course the time and duration. A sleep mode if enabled would mute audio after specified time. This Timer Profile should be able to directed to an open SmartSDR or a Maestro on the LAN.
Once done, this could be taken to another step, I'll call AutoMonitor. If selected in the Timer Profile, it would switch to the desired memory setting and monitor the frequency. If activity is detected, signal levels for periods of time to distinguish between QSO and crashes, then send a custom alert notification via email or text.
What do you think Mark?
- 683 The Flea Market
