H?ow to run Two Series 6000 on the same LAN and setup remote access ports
Martin Boroff
OOur Club would like to setup our field day site with a 6600 and 6400 and have operators access via SmartSDR. I can use the usual ports (4993 and 4994) for one of the radios. What should I use for the second radio and are changes to the remote operators required.
If you are not going to run it over smart link then just put them on the same LAN,
Each radio user will have to login to the PROPER radio in the SmartSDR Radio chooser, SMARTCAT Radio Chooser, and SMARTDAX Radio Chooser otherwise operator A may have SmartSDR on Radio A and CAT and or DAX on Radio B and visa versa.
Make sure in the SETUP tab you DO NOT have "Autostart DAX" and "Autostart CAT" checked and start these manually so you make sure you get the correct radio,This get's confusing using data modes if they grab the wrong radio.
Good luck
Bret
WX7Y
There is a "--serial=" command-line argument to point DAX/CAT/SSDR to the correct radio. Just put that into a Windows shortcut and start up using the shortcut. No chooser needed.
Bret
Thank you for the information. I get the startup options for the users. Correct me if I am wrong. I believe I need smart link because users will be remote. I think the answer might be use a different pair of TCP and UDP ports on the second radio.0 -
When you said same LAN I miss understood
If the two radios are on the same LAN a separate pair of ports need to be setup as OUTGOING ports in the Smartlink settings and your Router and I use Two different SmartLink logins one for each radio
Each user logs there computer into the SmartLink account of the particular radio they want to use, at least this is how I do it here.
DAX still doesn't work for most things over SmartLink though
This is what I have had to do for mine to work hope this helps you.
73's
Bret
WX7Y
Thanks for the reply, Bret. You have given me something to work with. I'm not sure why you have DAX trouble. We have five Flex radios that share the same login. They are in five different homes. SmartSDR users select which radio that they want to use from the select screen. We use DAX for voice or digital apps like WJST-X. Nobody has reported any issues with DAX. Is this setup using smart link or am I confused?0
Yea with SmartLink for Voice using the computer PC MIC audio is flawless but the DAX digital stuff has issues, If I run through my VPN and not through SmartLink then all is well.
By the way the Remote PC MIC for Voice DOESN'T use DAX If DAX is enabled then PC MIC audio is blocked at least on my 6700 and 6600M, a lot of times I don't even start DAX unless I am going to run Digital.
I run Remote 99% of the time I operate so this isn't new to me.https://community.flexradio.com/flexradio/topics/dax-and-remote-audio-smartsdr-2-0-19 but this must have changed with the resent updates if it works for you.0 -
Thanks so much for your help.
I think we operate oppositely. I am 99% digital because I operate in the family room of my YL's house and the radio is remote. Thanks for thew info on DAX. On the 6600 I have to enable DAX and PC Mic and VOX. Sometimes the spacebar does not activate the VOX button so I just click the button. I am running Windows 10 under Parallels on a MacBook. The only idiosyncrasy I find with the Mic is that if the Laptop Mic is not set for default I get not mic to work. Why it gets changed from default I don't know. Just FM.
Take care and be safe.0
- 693 The Flea Market
