smartsdr update from v2.6.1 ?
Carl K5HK
Carl K5HK Member
When might we expect update to v2?   Many of us not contester so v3 not attactive but further improvements and fixes to v2.6.1 longtime comming.
  • KP2L
    KP2L Member ✭✭
    edited May 2020
    I second that question!!!
     In particular, will this fix from V3.1.11 be instituted in a new release of the V2 software?
    Corrected Issues Related to SD Card Corruption: Software improvements for increased SD Card stability during read/write operations. (J7741)
    After all no one wants their SD card to fail.
     And Hi Carl!!! .....I remember that name and call from the USVI!!!
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited May 2020
    Flex does not speculate on date certain for future updates.
    That said, if the SD Card Corruption issue is a factor in V2,6.1 (I am not aware if it is or not an issue for V2)  I would expect that it will be forthcoming sooner than later,   You go to understand that even the slightest changes to firmware can cause unintended consequences to the myriad of DIFFERENT devices that run the code- so unfortunately it takes time to test as many possible variances of configurations before releasing software.
  • KY6LA_Howard
    edited May 2020
    @Carl.... I understand that V2 has been feature frozen for some time now and the only changes to V2 will be bug maintenance updates.
  • Michael N3LI
    Michael N3LI Member ✭✭
    edited May 2020
    Version 3 is not a contesters only version. Only reason not to update is is you don't want to spend the money. As Howard notes - there won't be added features.
  • Carl K5HK
    Carl K5HK Member
    edited May 2020
    Thanks for the info gentlemen.  73
