maestro Version Selection
The last update with alphanumeric sorting in the version selection accidentally leads to the wrong selection because you accidentally quickly select the top version incorrectly. The current one is somewhere in the middle between older versions. A chronological sorting according to actuality would be better than the alphanumerical sorting. What do you think?
Slow down and read what you're doing. Theres operational issues needed worked on that aren't social problems giggle0
Thats why I had a hard time with the update . . . Was looking for it up top and it was in the middle0
That's why firmware developers often use fixed number notation mostly, like eg. 3.1.011 and 3.1.008 in the modern age ;-)
FRS Users need a button to remove old version FRS listen your users !!! :-)0
I only use one version, because it's the only one not needing downloading or uploading it stands out.0
All is fixed now you can breath once again.
Ian
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
