Noise in a waterfall of WSJT
Enrique Rabczuk
Enrique Rabczuk Member ✭✭
I use two Slice and two WSJT instances,
Example: When TX at 14.074 a continuos noise appears in the WSJT waterfall that is at 18.100. The same occurs n the waterfall where the frequency is 14.074, when TX is from 18.100. It is a normal? Pkease see attached file.image
