Slice Master skimmer spots to N1MM in SO2R often only to one bandmap and not two
Kari Gustafsson SM0HRP
Kari Gustafsson SM0HRP Member ✭✭
edited April 2020 in SmartSDR for Windows
Hi!
I have worked with lastest slice master version in SO2R mode in contests with N1MM so that it sends skimmert spots to each radios bandmap corresponding to each indivual slice. But strangely enough often I only receive spots in N1MM bandmaps in only on bandmap for one slice and not both bandmaps.  Each skimmer works as they should and they list correct stations on each slice´s skimmer. Has someone else experienced the same behaviour and solved this anomaly?
Trying different DAX  channels for slice master makes no difference.
