want to run my 6400 remote
DonE
i have both a modem and router in my network and i am going to run individual cat 6 cable for my 6400 and my desktop do i connect my 6400 and computer to the modem or the router ?
Router.
Steve KD2OM0 -
If the modem has an integrated switch (i.e. multiple network ports), you can plug both into that if you have enough ports to go around. If the modem only has one network port, that will plug into the router and the Flex and computer will both plug into the router. Either way should work.
Len, KD0RC
If the Modem has a built in router then you want to plug into the Modem as you DO NOT want to be double NATed.
If you don't have enough ports on the Modem and it is also a Router I would add a 1GB 8 port switch and plug everything into that switch, just remember the MOST important thing is you DON'T want to be double NATed
Bret
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
