KO4OO
Thurman Williams  Jr
Thurman Williams Jr Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
6400M and Q5 I have several HF rigs hooked together with a Alpha Delta switch box. one being my 6400M.. question?? when using my 6400M and the Q5 transverter. Will it be safe to transmit with one of my other HF rig with the 6400M on  using it  with a slice open to monitor 2 m with the transverter without taking out the front end .... Alpha Delta says 70db of isolation unused selections are switch to ground. Still worried when I'm transmitting with my Yaesu I'll take out the front end of the flexradio if it's on at  the same time monitoring 2m with the transverter.. anyone have any thoughts Jr.  KO4OO
  • WK2Y
    WK2Y Member ✭✭
    edited April 2020
    I don't know exactly how you do it, but I would think you would want to start at 5 W or less and while slowly raising the power,monitor the input levels on the Flex.
    73, Stay healthy,
    Bob, WK2Y
