RadioSport RS60cf settings?
Steve - K6SRS
Steve - K6SRS Member ✭✭
My 6500 using current SSDR software shows no equalization settings for the RadioSport RS60CF headset.  I only see DX or WIDE M207,M208 and M350 models.
Are any of these equivalent?
If not, recommended settings?
Update - Ah, I see I have to know which microphone is used in the RS60.  How do I determine that?  I know it was set up for a FLEX 6500.
  • Patrick
    Patrick Member ✭✭✭
    Do you have your original invoice? And or original order?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited April 2020
    Steve, either way, after you find out and you find the right profile, don't stay with that. those profiles are meant as a staring point. Now you need to make EQ setting for your voice.
  • Brian Denley  KB1VBF
    Brian Denley KB1VBF Member ✭✭
    edited April 2020
    It’s either dynamic (no bias) or electret (needs bias).  Try it with bias off.  If it works, it’s the dynamic cartridge.
  • Steve - K6SRS
    edited April 2020
    I wish
  • ChrisCC
    ChrisCC Member
    I just bought the same headphones and my invoice says electret. So I guess it needs bias. I sure would appreciate suggestions on all the other million settings related to how the microphone operates
    Hi Chris, Ken Wells, NM9P put together a really good set of videos on YouTube. He describes how to set the SmartSDR controls using Full Duplex (FDX). You get a visual as well as an audible sense of what the settings are doing to your audio. I usually record as I go because I can't talk and listen to myself at the same time. Do a search on YouTube for NM9P and I think you will be pleasantly surprised by how informative the videos are.
  • ChrisCC
    ChrisCC Member
    I saw that video once before I got my radio. I need to go back and look again. Now you have given me his call and name I can find it again.
    Thanks!
