Flex 6500 & MMSSTV
John - ZL3TRR
John - ZL3TRR Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
I have a Flex 6500 and am trying MMSSTV . I have the power set at 80 watts but I note that the power signal  fluctuates between 0 and 40 watts as the picture is sent. . its not a constant power reading as with ft8,  Is this correct ??  or am I doing something wrong ?
  • Dudley  WA5QPZ
    Dudley WA5QPZ Member ✭✭✭
    edited April 2020
    John,
    Be sure that you check your Transmit bandwidth,  but the output is much wider than FT8,  and will vary quite a bit also.
    Dudley
    WA5QPZ
  • Paul - K6HR
    Paul - K6HR Member ✭✭
    edited April 2020
    Yes the SSTV signal varies, especially if you have "Vari SSTV" checked on the Setup MMSSTV > TX tab. Also check the "Digital output level" slider adjustment. I don't use the "Vari SSTV" setting myself. You can see how your transmitted SSTV images are received at my QTH near Los Angeles here: http://k6hr.com/sstv.html
  • tod_WE5TR
    tod_WE5TR Member ✭✭
    Could one of you with a successful setup send screen shots of the MMSSTV settings windows? I have audio and PTT, but am failing to get frequency and other such radio control to work. WE5TR
  • James Del Principe
    James Del Principe Member ✭✭✭
    edited April 2020
    John, it is correct. Slow scan is an analog transmission. At any moment your power out is analogous to the intensity of a point on a given line........ I have not done slow scan in many years but it really is a lot of fun. I hope you do well.   Best 73, Jim
  • John - ZL3TRR
    edited April 2020
    James, I appreciate your comments . keep safe best 73 John
    edited April 2020
    John, I wish you and yours good health in troubled times. and maybe a few sun spots too.    73, Jim
