Flex 6400M vs. SmartSDR
Maxejb
Can I access all of the features of SmartSDR on the 6400M without using SmartSDR
In a short answer, no.. But there are several features of the M models that are not in SmartSDR, programed function keys for one. But if you have the M model, you can always access the radio with SmartSDR and still be able to operate the radio standalone without any external computer or IOS device..
Hope this helps,
Dudley
WA5QPZ
The only reason I have SmartSDR is so that I can use the Flex Control and a mouse with my 6400M.0
...and you should be backing up your profiles with it if you are using profiles.0
Since the M model radios are basically running a Windows OS, and the M model radios have a USB port, it would be nice for non SmartSDR users to be able to plug in a USB mouse to the M radio and operate the M model radio screen functions from that mouse. This seams like a very simple OS modification requirement to the OS.
I DO NOT have any profiles as I darn near ruined my amp because the profile did not drop the pwr from 100W down to 45W, The end of profiles for me.0
