SmartSDR ATU Not Installed
Tim N9PUZ
SmartSDR V3.1.8 w/Flex6400M. My radio has the Flex ATU installed. It works fine from the front panel of the radio. When I operate the radio via SmartSDR the ATU controls are greyed out and hovering over them I see a message that says the ATU is not installed.
Have I missed a setting somewhere?
Tim N9PUZ
Tim N9PUZ
my 6600M 's ATU works fine over SmartLink here so maybe check your network settings on the SmartLink Login screen and see if your network port forwarding is still Green.
hope you find the issue
73's
Bret
WX7Y
Connections look like the video and as described in the docs. At this point I'm just logging in from one of two other PCs in the house on the same network. Every other feature I've tried seems to work fine.
I have submitted a support ticket for this issue. I will share what we learn as things go forward.
Tim N9PUZ
- 685 The Flea Market
