60 m avec flex 6400 ? pas d'émission ??
pas emission sur 5.363 mhz
  • K3SF
    K3SF Member ✭✭✭
    edited March 2020
    hi alain
    i am not sure when your country permitted  access to 60m...
    so you may need a new turf file from flex to gain access to transmit on 60m
    If you do have proper turf file
    then
    it is important to set transmit bandwidth to 2.9khz or less
    and
    to set mode to usb
    if using FT8 mode be sure split operations to off in the wsjtx radio parameter. the flex radio needs to be set to DIGU mode and verify transmit band width of 2.9khz or less.
    Paul K3SF
  • Alain Moisson
    Alain Moisson Member
    edited March 2020
    Merci Paul pour la réponse,oui nous sommes autorisés en France pour le 60M.Je pense que je n'aie pas la bonne configuration, Je vais chercher encore merci Paul et 73's à tous Alain F5PJG
