What basic steps are required to connect smartlink/smartsdr ios via a remote (eduroam) network?
Jim 2E0FOA
I have a 6300 at home on my LAN, and can connect via smartlink over 4G on iPhone or tethered iPad, having enabled ipV6.
At work I can connect to the UK university network called 'eduroam' however although SSDRiOS shows the radio as available via smartlink, it can't connect.
I assume it's necessary to request a firewall change to open port(s)? By default ports will be locked down and opened by exception.
I have tried using Fixed LAN mode and entering the WAN IP address of the 6300 but no luck
- 117 Aurora
- 323 Shack Infrastructure
- 228 Networking
