N1MM+ SO2V configuration ?
Steve Killeen
I would like to configure my N1MM+ with my 6600 to work with two slices that each have their own antenna.
Slice A: 20 meters CW
Slice B: 40 meters CW
Is smartSDR capable of doing the SO2V mode ?
Steve
Steve
Yes, you can do that, but the operating mode is SO2R, not SO2V which is defined as both receivers in the same band. With SO2V, you cannot have separate RX and TX antennas.
You must use two panadapters and have a slice receiver in each. Then you can configure separate RX and TX antennas for each slice.0 -
I have the 6600 setup doing Slice A: 20 meters CW / Slice B: 40 meters CW .
Where I get confused is how do I setup N1MM+ to follow the two slices. I saw the SO2R document for the 6700 but it talks about SSB and DAX streams etc... Looking for a CW setup.
I got it working .... Followed mostly the instructions in the 6700 SO2R N1MM+ setup guide.
That is great news.1
- 417 Community Topics
- 716 The Flea Market
- 224 SmartSDR+
- 471 SmartSDR for Mac
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 149 Contesting
