SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
SDR-Bridge v3.1.0 update available now!
Changes to SDR-Bridge include:
- Improved updating of the display when changing stations.
- Attempt to improve removing of CW Skimmer ghosts that interfere with proper startup. (Please let me know of any startup problems.)
- The Quickstart guide has been updated. Thanks, Al NN4ZZ!
Enjoy!
Ed / W2RF
For Skimmer Server and RTTY Skimmer Server users:
The revamped v3.1 driver now will run both CW and RTTY skimmers simultaneously. To set this up:
Configure each of the two skimmers for the number of desired bands. The total should not exceed the available channels.
- Configure the two skimmers to use different telnet channels.
- Make sure enough panadapters have DAX IQ assigned and are not active in the DAX app. (The DAX app doesn’t need to be running.)
- In SmartSDR, if running multiple stations, assign PTT to the station you don’t want to run the skimmers. Typically SmartSDR running on a PC would host the skimmers with up to 4 channels, and a Maestro would be the PTT client. (If running on two PCs it is possible to have up to 6 skimmers. The setup currently requires a special filter.txt file. Let me know if you want to try that.)
- Start the skimmers! Order doesn’t matter. (As usual the panadapter center frequencies will be locked for skimming.)
Ed, Thanks for improving the bridge. I am not near my radio so cannot try. Here is a question. The last I tried it the panadapter was frozen to the center frequency and when I moved the frequency too far away, I did not have any visibility on the listening frequency. Panadapter and waterfall were showing a window that did not include the current slice frequency. Is that something that works differently now? Andy KU7T0
There seems to be a problem launching the pDF CW Skimmer Quickstart guide.
Andy,
SDR-Bridge and CW Skimmer do not lock panadapters, and never have.
The Skimmer Server and RTTY Skimmer Server driver locks associated panadapters to a frequency designated by the host configutation files. Use an additional panadapter for your slices. for example, use SSDR panadapters for the skimmers, and Maestro for interaction.
Ed / W2RF0 -
Hi John,
I’m not aware of the issue launching the guide on the QRV web page but it is also available on my web page at:
http://nn4zz.com/Data/NN4ZZ%20CwSkimmer%20Bridge%20setup%2019-Feb-2020.pdf
Regards, Al / NN4ZZ
The link is fixed. Thanks for the report.
Ed / W2RF
Hi,
Been using sdr-bridge v3 with much pleasure up untill recently. Maybe looks like a recent windows update is responsible for it not starting up anymore at all. Anyone else experiencing this on windows 10?
regards and greetings,
Leo de Blaauw - PA1LDB0
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
