N1MM port conflict with SSDR 3.1.8 - Any recommendations?
KD3RF
Member ✭
N1MM port conflict with SSDR.
Anyone else getting this error message?
Not sure if problem is in N1MM or SSDR.
Both programs work OK when in standalone mode.
When running them together the N1MM bandmap fails to follow the radio when changing bands and N1MM does not record the correct frequency in the log.
Is there a recommended solution?
You have two COM20 ports.. That's the dup N1MM is highlighting.1
You're right, Tim. THANKS!
I'm in the midst of the contest at the moment. I'll fix it when things slow down.
73 es gl in test
- 997 Maestro
