Remote FT8, Win 10 settings problems
Dragan 4O4A
Dragan 4O4A Member ✭
edited February 2020 in Third-Party Software
Hi all,
I'm running remote Flex 6700 controlled by Win 7 SP1 laptop not in the same LAN, and have no problems with FT8, CWX, CAT, SSB, DAX, etc, everything works fine.
However, when I want to use another two laptops with Win 10 configurations, I stumble upon these problems:
On one laptop, FT8 TX audio is distorted and I cannot make it looks nice on control waterfall.
Even if level of TX audio is -20 to -10 dB, signal is 150-200 Hz wide and distorted.
DAX TX level is about 50%, PWR level in JTDX is about 75% adjusted to show TX audio level "in green", less then -10 dB. Radio mode is DIGI-U.
On another laptop, I can't even transmit. When I hit "Tune" in JTDX, TX starts but drops after 1 second or less. The same happens with WSJT-X.
After some hit-and-try, even RX DAX channel 1 stopped to respond.
The same happens with 10W and with 300W (by PGXL).
Restart of DAX, radio didn't help.
First laptop with Win 7 SP1 still controls radio flawlessly.
Any idea?
Regards,
Dragan, 4O4A
