Slicemaster config panel does not open
Jim
Trying to run the latest version of Slicemaster to run with my 6400. When I click on the exe file it appears on my taskbar but the configuration panel does not open so I cannot configure it. Any help would be appreciated. By the way Im trying to run on a Win 10 machine.
Is another window open telling you that the program is suspicious and asking you if you want to continue? Check the task bar for the Windows shield and/or use alt-tab to cycle through the open windows.
Bob, WK2Y
Thanks for the reply. No, no window saying the file is suspicious. The slicemaster icon appears in the taskbar but the config screen will not open
What virus protection software are you running? Is it showing it as being blocked and can you create an exception for it?
Im running Norton 360. Ive tried running slicemaster with Norton disabled and get the same result0 -
You might try downloading again. It's a self contained program so there are no installation issues. And if still no luck I would drop the author Don,K1DBO a note. He is real good about getting back to folks.
Sounds like it might be off screen?
Try shift right clicking the taskbar icon and select Move. Then use your arrow keys trying up down right and left and see if it comes back on screen.
Thanks Bob. Ive downloaded it a number of times. No luck. Ill try Don0
- 116 Aurora
- 323 Shack Infrastructure
- 228 Networking
