6600 forever blinking green light
Mark_WS7M
Mark_WS7M Member ✭✭✭
My 6600 was offline during a ham fest and I attempted to remote boot it unsuccessfully.  When I got home I found that on power cycle the green light just continues to blink on boot up.  It never finishes.
Is this SD card corruption?
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited January 2020
    I don't think it is, something got messed up upon your boot up, I recommend resetting to factory reset, that should correct what is scrambled.
  • Neal_K3NC
    Neal_K3NC Member ✭✭
    edited January 2020
    Try unplugging the power cord from the radio, count to 10, then boot up and see if it changes. If not, power it down, then to a factory reset (hold the power button in until its light turns white then let go) and see if it changes anything.
    If not, create a helpdesk ticket!
  • Bob- W5TX
    Bob- W5TX Member ✭✭
    edited January 2020
    Mark, I believe Neal’s answer is best bet.
    Bob w5tx
  • Santiago Mejia HI8O
    Santiago Mejia HI8O Member ✭✭
    edited March 2020
    Mark...did you fixed it?
  • Mark_WS7M
    edited January 2020
    Thanks Bill, Neal, Bob ad Santiago,
    I still don't know what the real issue was but I have it online again.
    So the story was at a hamfest I was talking about how great the flex is and how I can operate it from anywhere.  So I pulled out my phone and tried to connect but no radios were shown.
    I figured that it could be two things:
    1) I put in a new upgraded IQRouter over Christmas and really had not tried remote since then.  I figured maybe it was a network setup issue.
    2) The radio needed a reboot.
    I have a small web based Pi app I run that can reboot my radios (toggles the REM on port) and I can also completely disconnect power from the radio as well.
    I did both of those things and the radio never appeared.  So I figured it was a #1 issue.
    I got home and even on my LAN I could not see the radio.  So I logged into my monitoring camera and rebooted the radio.  That is when I saw it stay in flashing green mode.
    Unfortunately I was tired and didn't want to deal with it.  So I simply depowered the radio using REM ON port and decided to wait until morning.
    This morning I went out to the shed where the radio was and I physically pressed buttons.  The radio again would not ever come out of blinking green mode.   So I pressed and held the power button until it went white.  It stayed white for a very long time then blinked some various reds then shutdown.
    I figured "oh boy... problems".   So I unplugged everything and brought the radio inside.  I put power to it, plugged in a network cable and turned it on.   It booted just fine and I was able to see it in SSDR.
    So I moved it back to the shed, plugged everything in and now it is up and running just fine.  Not exactly sure what happened but I will have to keep an eye on it.
    Thanks for all the suggestions!
    Mark
