Stream Deck Question
Harold Rosee
I have my stream deck working well for the Flex as well as a bunch of Computer task. If you don't have one you are really missing out.
But I have a question for you guys who are using them. I was watching a YouTube video of a guy using it on his Flex. From what I can tell when he holds down his Frequency up or down button it moves the frequency up or down until the button is released. Mine doesn't do that nor can I figure out how to do that. Mine just moves once for each push by the step amount.
Does anyone know how to make the key repeat like that?
Harold
W5ZZT
Harold
W5ZZT
I hope this helps someone else.
I didn't get any replies here so I wrote Jose, EA5SW a email. He is the one with the StreamDeck video on YouTube.
He was kind enough to send me his StreamDeck Profile. It still left me stumped but I finally figured out what he is doing and it's pretty slick.
Mark coded hotkeys that you can define in FRStack. These hotkeys, at least the Frequency up and down keys, repeat when you hold them. So in FRStack you define something like ALT+F1 as frequency up and then ALT+F2 as frequency down. Then you go into the StreamDeck app and setup up a button as a Hot-Key. Set the hotkey in streamdeck to execute your hotkey you defined in FRStack.
I would have never in a hundred years thought of this. Instead of using the custom REST that Mark wrote for Streamdeck to interface with with the SmartSDR API he just used the built in Streamdeck profile to talk to the hotkeys he defined in FRStack.
Pretty slick. So a big thank you to Jose.
I hope my description of what he did makes sense. If not feel free to ask.
Harold
W5ZZT
Always looking to be in the fast track I would appreciate if you sent Jose's file. Curious how he is doing it as well. N9IO at Hotmail dot com.0
I will forward you the email but it's not all there meaning the actual hot keys are defined with the hotkey editor in FRStack. Look under "View" in the FRStack menu. You define a hotkey there to make it do what you want.
Then in streamdeck there is a "hotkey" under the "System" on the right menu. You just drag it do a button. Then you press the key you want it to perform and that's it.
So in FRStack I defined ALT+F1 to be volume up in FRStack and ALT+F2 to be volume down. Then in Streamdeck you define the hotkey.
All you will see in his profile is the Hotkey definition. I had to figure out what he was doing. What is interesting is the Hotkeys in FRStack repeat while the "REST CALL" that Mark wrote for the Stream Deck don't. I wrote him about this.
Harold
W5ZZT
Hi, interesting. Is there in FRStack a hotkey for choosing RXA instead of ANT1? Would be convenient to be able to toggle between the antennas on 160-40 meters when copying a weak signal. On RXA I have a beverage antenna.0
