Fldigi not working under n1mm
John, G3WKL
John, G3WKL Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
Trying to setup for a local datamode contest (RTTY and PSK63) and can't get N1MM+ and Fldigi to modulate the 6700. On it's own Fldigi works fine, but when running under N1MM+ the 6700 goes into transmit (MOX light ON, and red light on the 6700 ON/OFF button) but no modulation, no streaming of the TX audio indicated, yet DAX button illuminated. When you enable a function key on N1MM+ RTTY trsnsmit audio is created and the waveform is displayed in the Digital Interface Window, it just doesn't get to the TX! Any suggestions?
  • John, G3WKL
    edited January 2020
    Problem sorted - I hadn't configured the Fldigi Engine properly (was wrong in thinking that it picked up the config from the main Fldigi program)
    Now to document the config so that it's easier to setup next time
