CW Weight
K1ESE
K1ESE Member ✭✭✭
edited December 2019 in SmartSDR API
Can I assume this listing from the SmartSDR TCP/IP API has not been implemented?
WEIGHT
Set the weight of the CW keyer to a specific value. The calculations that determine the length of a dot, space and dash are:
space = 1200ms / wpm dot = space * weight / 50 dash = space * weight / 50 + space * 2
C[D]<seq_number>|cw weight <weight>
<weight> = a number between 0-100 setting the relative weight; default is 50
K1ESE
