Problem when sending CAT commands to retrieve the frequency from SSDR for VFO A.
Ken Nicely
Ken Nicely Member ✭✭
edited January 2020 in SmartSDR for Windows
When sending FA; or ZZFA; or ZZIF cat command to SSDR I am sometimes getting a wrong response after changing bands.  It does not happen all the time. I am running v.3.1.8.  In the example below I was on 40 meters and switched to 80 meters.  I tried all three commands and got the wrong response.  I have modified a program I wrote years ago to allow for adjusting the receive frequency via keyboard.  All is working well, except sometimes when I switch bands the cat commands give me the frequency for the wrong band.  A copy of my program can be found here.  https://drive.google.com/open?id=1WUboZ2uuyxCBqxWtVnIN9D7g1DGJ_DOk  Just unzip and run it.  If you use it for a little while you will eventually go to switch bands, press the left or right arrow to adjust the frequency and instead it will switch bands.
  • Ken Nicely
    edited January 2020
    Any thoughts from anyone on this.  I have discovered that it occur swhen I shut down SSDR and CAT, but leave my program (K-Keys) running.  Then many hours later when I restart SSDR and CAT and issue a command to get the frequency from the still open K-Keys program I get a wrong frequency returned.  This continues to happen until I restart SSDR. CAT and K-Keys.
    Ken KE3C
