Line level audio into Flex 6400 .. audio extremely hot by the time radio modulates 100%
Kevin J. Darrah
Kevin J. Darrah Member ✭✭
edited December 2019 in FLEX-6000 Signature Series
I run AM exclusively with my Flex 6400. Through the Mic input all seems well for the most part. I decided to run audio into the 15 Pin Connector. Now I am extremely puzzled.
As long as I keep the modulation levels somewhere between 50% and 75% the audio is satisfactory.. When I try to modulate the audio too 100% as verified with a scope the audio is so excessively hot, even before the leveler encroaches 0 DB....
There is no hum, no anomalies etc.... On the audio .... AS long as I keep it at 50% ....  Wondered if anyone else had noticed/tried this on AM and had similar results.
Kind of a strange situation, thanks.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    Are wiring your mic directly to the 15 pin connector? or using a small mixer?
  • Rod KQ6F
    Rod KQ6F Member ✭✭
    I also have a 6400.
    I hooked up an audio oscillator to pins 1 and 2 on the ACC connector, selected ACC input, AM mode and watched the RF envelope on a scope as I cranked up the oscillator output.  Everything perfect from zero to 100% modulation - no erratic behavior.
  • Kevin J. Darrah
    Using an Omnia Volt.... running that into an attenuator to bring it down to consumer level audio, then a 600 ohm audio xmfr .... Using pins 1 and pin 10 on the connector into the Flex.
  • Kevin J. Darrah
    I thought pin #2 was for powered speakers... I will have to check that out, thanks
  • Rod KQ6F
    Rod KQ6F Member ✭✭
    I fed the audio into pins 1 and 5.  Pin 2 was a typo.
