no display flex 6400 only thing on screen is dax control panel and dax control radio is recieving bu
steven smith
Member ✭
no display flex 6400 only thing on screen is dax control panel and dax control radio is receiving but no display running 3.1.8
I have never used DAX or need it or want it, but all of a sudden it is popping up on my screen as well.
Just another annoyance. i just delete it.
Andy... W3LI0 -
In the menu just tell it to not load on startup. No more annoyance.
the smartsdr window is blank but i hear it receiving i don't get it called flex 3 times today no answer back
SSDR must be running in background if ur receiving, maybe it's minimized ? Maybe I am missing something here ?0
smart sdr is running in my task bar but if i put my mouse on it its a blank window
Either there is a setting with the Windows screen to cause this? Flex support will likely ask you to do a Factory reset, and re boot your computer before they go further.
i just changed out computers and problem is gone radio is fine wonder what setting could be off on computer i use it for the internet and display works fine any idea
could you make a screen shot so we can see what your seeing?
