PILOT PROBLEM 28 MHZ ON TRANSVERTER 144 MHZ WITH FLEX6400
massimo lusardi
Member ✭
Hi everyone, I have been using a 28/144 Khune trasverter for about a year, with input control of max 0 dbm I have never had any problems so far, now the flex output is set to 0 dbm, it has dropped by 15 dbm without doing anything, if imposed by the 6400 + 15 dbm setup I have a correct exit and everything is stable, what happened? no one can heal me? Software or Hardware Problem?
below you see the flex signal with setting 0 dbm you have to consider the 10 dbm of attenuation of the analyzer, fifth we are at -14.75
- 694 The Flea Market
- 357 FLEX-8000 Signature Series
