Slice Flag issue when using LSB.
Glenn Depp
The Slice info covers a large part of the upper portion or peak park of the slice when in LSB. USB the slice info is off to the left which makes it out of the way, only LSB sits directly on the slice. Can this be made to switch to the other side to allow slice to be viewed?
You can click on the slice letter(A,B, etc.) and have the flag disappear. Maybe that will help some.
There should not be any info that close to the bottom of the flag anyways. I don't understand what it is blocking from sight.
Well, yes the slice flag is always to the left of the carrier line, unless the flag gets too close to the left edge, then it moves to the right of the carrier. So, if you want to move the flag to right of the carrier, slide the panadapter to the left until the flag changes sides.
To Bill's point, the up and down arrows in the upper right control the scale of the panadapter, so clicking on the up arrow "compresses" the scale to make the peaks lower. Also, using the mouse to slide the scale down will lower the position of the peaks.
Yes I am aware I could simply make the entire flag disappear that is not really what I am wanting as I also want the ability to quickly change between 4 slices and be able to mute the sound from those not active. I normally have in use 4 slices and at times need to be able to switch between them quickly which requires the flag to be visible. I recon I will try this out. I have 1 monitor dedicated to the SDR, the CAT and DAX are minimized. I also have 8 other windows up displayed as well in their little sections so I can see the activity going on with them as well. This makes the SDR software display on the bottom 50% of the screen, so I have 2 slices on top and 2 on bottom. This thin section for each slice is my issue but sounds like it is how it is. I will work with it. I normally only use USB anyway. Only amateur use is LSB on the lower bands. Thanks gents...
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 991 Genius Products
- 330 Shack Infrastructure
- 234 Networking
