'There are currently no radios available'
Chris Walker
Running Windows 10, with my Flex 6400m. I can go direct from radio to computer or radio to router (ether cable) and still cpu does not see radio (or vice versa). Just same message as above. It has worked for over a year on Smart SDR and hooked everything backup after we had weather and no joy. Using the radio stand alone work perfect but want the Smart SDR back... I feel like it is simple and Im just missing one little thing...
Did you try re starting your router and radio?
Are you using a LAN switch? If so did it take a hit with static in the weather you experienced. I have 8 port LAN running to radio and internet and computer, works great...Just a thought...0
Chris, believe it or not, cables can go bad...I had an ethernet cable go bad...check them out or swap them out for new cables....Just another thought...0
Thank you! But I bypass and go from radio to computer direct and still same thing...0
Thanks Bill. Yes, I have restarted both several times...0
Thanks Harry. Yes I have tried several cables. New that goes from radio direct to cpu and still same message. Cant understand it...?0
Is there anything in the cpu that might have been effected by the weather. I did not disconnect it. But it works fine on all other functions. email, internet ect. Have it direct to the router via ethernet cable...0
Make sure you don't have a software firewall blocking it.0
Great suggestion Larry. All Flex products are allowed thru firewall... I now have it cabled direct from radio to cpu. Still not talking to each other... Again both computer and radio are woking fine.... huh?0
Chris I could be off here but bear with me as I had a recent happening similar to yours and this is the story.
I "had" a serious RF issue with RF getting into my network/radio system because my internet is a radio modem on my tower very close to some of the TX antennas.
So experimenting I broke that internet run with a pair of fiber optic converters (3 foot long fiber run.)
NEXT I put the radio (6600) Maestro and computer on a separate switch so they had no internet and separated from the network, the IP's assigned without DHCP from the router are 169.xx.xx.xx.
This worked great (no RF issues running full legal limit now) so temporarily I added internet with a wireless NIC to the computer only. Still working fine. Even ran a contest like this.
NEXT MOVE and lastly (where I am today) in order to get internet to Radio, Maestro and computer and IP's of 192.168.xx.xx from the router by DHCP I turned off the wireless NIC and attached the separate switch to the router with an additional pair of fiber optic converters. (again a 3 foot long fiber run.)
LAST POINT: When I did the last step I had to restart radio, and computer a few times before the computer SAW the radio THEN once connected the connection was IFFY. Doing a speedtest on the computer the connection was slow although other computers on the network were normal.
A reset of the radio and couple more restarts suddenly lo and behold this system is all working at full speed, excellent!!! Speedtest.com test AOK! Radio, Maestro, computer love each other once again in true harmony, (pun.)
I have no other explanation, certainly NOT scientific as I am no network engineer.
Keep driving at it Chris, hope this could possibly help you somehow.
Clay N9IO
Chris:
You mentioned restart of the radio. Have you tried a factory reset or was that what you meant when you stated restart?
Gayle K0FLY
If the front panel is active, you can't connect from ssdr on pc - unless you're running v3 software. You can disable the front panel from the menu. Don't have the exact procedure at hand. 73 gl Martin AA6E.0
Hello Gayle. I have not done a factory reset. Actually didnt even think of that. I might go there if I don't get things going by afternoon. Thank you.0
With the pc on and Smart SDR active, I then turn on the radio but it never sees the radio like it would on the past. At the bottom of the maestro, it does say Ethernet cable connected but no internet. Which is correct as I am going only from radio to cpu. aka Field day mode. So maybe something wrong with the computer...? Seems to simple, but I guess not... Thank you Martin, Chris
By the way, running v 2.4.90 -
You said you had a 6400m. Do you have a Maestro, too? Not understanding your setup.0
Didn't mean to confuse. 6400m (m=maestro). I do not have a separate display. Just meant the built in Maestro. Computer still doesn't see the radio. I have gone back and reviewed all the basic Flex SDR setup and they just assume the radio will see the computer as they skip right over it.0
Chris,
Go into menu from front panel of radio and look and see what IP address is assigned to the Ethernet port.Then with radio directly wired to PC open a command prompt. Type in IPCONFIG /ALL and see what IP is assigned to the PC Ethernet port. Both should be 169.254.x.x range.
Just a reminder, booth the PC and radio up agter they are directly connected.
Dave wo2x1 -
straght thru or crossed network cable0
Hello Dave, Thanks for the help. The radio is 169.254.x.xx However the PC is 192.168.x.x
Is this the issue? Ethernet cable connected from radio to cpu. The computer is also on wifi...0 -
yes it is0
OK good. So how do I sync the IP addresses? Thanks!0
the easy way is to allow the flex to reboot hook it back to the network first then reboot
hook the pc back to the network reboot the the pc as well after the flex
do the ipconfig /all if it still does not connect1 -
Look under FlexRadio Settings and make sure under Radio Setup- Network -Advanced - you have DHPC selected1
Sounds like you may have Static selected1
O also -- you need DHPC turned on at your router0
Make sure on the PC that Ethernet connection shows 169.254.x.x when connected to the radio.The WiFi can show the 192.168 IP.
if the Ethernet adapter is not showing an IP then maybe it is disabled since you use WiFi for Internet access.
if you would like remote assistance via TeamViewer you can email me and we can talk on the phone. My call at ARRL dor net.
I have time anytime tomorrow.
Dave wo2x1 -
Thanks for everyones help.
Quick note: In the back of the modem/switch where the ethernet ports are, there are no lights (green/orange) on. I am plugged in to the first 2 slots (radio and cpu). The front of the modem is online and all looks good and we do have internet. Issue?
Is this a device provided by your Internet provider? Sounds like the ports may not be enabled. You should see link lights. Make sure the cables are firmly plugged in.If still no link lights, call your Internet provider in the morning.
Dave wo2x0 -
Thanks again Dave, I will do it today. Im hoping this should solve the problem. We did have lightning strikes very close the other night. All radios were disconnected. Maybe it effected the modem....?0
Very possible. In that case call your ISP for a service call. Let them know you do not see link lights on modem/router when cables plugged in. That way a tech can have a replacement modem/router with him.0
- 713 The Flea Market
- 208 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 990 Genius Products
- 329 Shack Infrastructure
- 234 Networking
