FLEX-6700 transmit on digital modes quit working
Doug
Had Fldigi and WJST-X working. But now neither produces any transmit audio out of my 6700 running SmartSDR v 3.0.27 under Windows 10. DAX Control panel shows blue TX and transmitting, but with TX Gain at 100, no audio level is shown with either program indicating transmission of digital data. Windows Sound control panel shows input level at 100% for DAX Audio TX. P/CW panel shows blue DAX. Slice A panel shows red TX and DAX channel 1. Fldigi shows Playback on DAX Audio TX. However, MIC still yields transmit audio. Windows feature update to Windows 10, version 1903 failed to install on 8/29. (version 1809 successfully installed on 2/21/2019.) Most recent Windows Quality Update was KB4523205 for Windows 10 version 1809 successfully installed on 11/12/2019. (tested this on 80 m, 20 m, and 2 m.)
Did you check FLdigi and WSJT to make sure the setting pointing to DAX audio path has not been lost ? Andy K3UK0
Thanks for the reply. I checked that Fldigi Audio Playback setting still points to DAX Audio TX. I also checked that WSJT-X setting still points soundcard output to DAX Audio TX.0
I think if there is a DAX Channel has turn RED then it is a Driver is broken issue due to windows 10 UPDATE you may not have noticed a WIN10 Update but that is what breaks the older DAX Drivers in 3.0.27.
You should probably uninstall every thing including the DAX Driver using the Manual DAX Removal method then install SmartSDR 3.1.8, https://helpdesk.flexradio.com/hc/en-us/articles/204975589-How-to-do-a-Complete-uninstall-of-SmartSDR-for-Windows-from-your-PC.
and the DAX Drivers https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers
This is pretty well documented by Eric a while back on this group, 3.1.8 takes care (SO FAR ANYWAY) of the Windows updates causing this that have been installed up to version 1903 plus a couple smaller updates.
Hope this helps and 73's
Bret
WX7Y
Thanks for the reply. Please clarify what is meant by "DAX Channel has turn RED." On the DAX Control Panel, the TX icon had a blue background. On the P/CW panel, the DAX icon had a blue background.0
maybe I red this wrong, you said "Slice A panel shows red TX and DAX channel 1."
If all the DAX channels are named correctly then never mind but Windows has a a bad tendency of renaming them which breaks them.
Bret
WX7Y
Again I'm going to say the weakest link in the Flex system is DAX. This software is flaky, sometimes it works flawlessly and at other times it's a pain to use.0
During the course of operation, digital transmission was restored.
Trigger event causing failure remains unknown.
Trigger event causing restoration remains unknown.
Suspect it could happen again at any time.0
- 685 The Flea Market
