Hi what are those stripes on the waterfall?
JOHN GREEN
Hi people.what are those stripes on the waterfall? watch from 0.58 seconds, there are even more bands. This is on all ranges (40 meters less than 20 meters). Antenna HY GAIN av-640 vertical. On the usual dipole 40 meters this is not observed.
https://youtu.be/rXge-XwFpu8
you posted this message twice so here is what I posted on your other thread
Looks like a noise source that may or may not be generated in your shack, Easy way to check is to pull off the coax connector going to the antenna and see if most of them go away or have a station in your general area look at his spectrum.
BUT it really looks like a noisy power supply or a wall wart, Plasma TV, computer monitor really anything with a switching power supply in your house or a close neighbors, It could be a furnace, washer or dryer that has a variable speed motor, very poor quality Floresent LED 110V / 220v light bulbs etc etc etc, you will just have to start by running the radio from a battery source and turn EVERYTHING off in your house usually at the breaker box and if it goes away then turn them on (1) one at a time and watch the noise to come back up
sooner or later you will HOPEFULLY find the noise generator and be able to Replace it, if it's your neighbors device causing it then GOOD LUCK .
73's
Bret
WX7Y
They are spaced roughly 60 Hz, this is what I experienced from the lighting used for Marijuana growing in my neighborhood, it looked like this. Monitor start and stop times, Watch for 12 hour cycles in the interference.
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
