How to make display setting stick and the same for all panadapters
David
David ✭✭
Is there a way to set a personal default that can be applied all panadapters and stick until they are adjusted individually with the option to reset back the personal default? Recently this has become a frustration. I have gone through all the panadapters and set them to what I prefer only to have that setting change when the band is changed or even return to the factor default when the SSDR is restarted.
  • KI4P
    KI4P ✭✭
    edited May 2020
    I was experiencing the same, last night I set display to level and saved to the global profile I have for each band. Not sure if it worked or not. Will know this evening when I get home
