Anyone able to run CWSkimmer while connected via SmartLink?
Lawrence Libsch
I've been able to run CWSkimmer using SDR Bridge or Slicemaster when operating locally. I am unable to run CWSkimmer when working remote via SmartLink. Has anyone been successful running CWSkimmer when operating remote via SmartLink? If so, please advise.
Larry, K4KGG
Larry, K4KGG
2
Did you set up DAX to get the Audio and CAT into your remote PC . Does the DAX channel stream ?
DAX IQ is not available via SmartLink. It consumes a lot of bandwidth. DAX IQ may be available using another type of remote connectivity but will need excellent speed and latency.0
Thanks for your replies.
The DAX IQ channel does stream using SmartLink (screen capture below.) Current version Slicemaster does not support SmartLink and SDR Bridge does not either.
Would a RPi VPN, ie connecting without SmartLink work? Is anyone with a VPN connection using CWSkimmer successfully?
Larry, K4KGG
My error, sorry. I missed the highlight in the changelog and had not bothered to try it.0
- 685 The Flea Market
