Remote PC USB Headset Problem
W2ECK
W2ECK Member ✭✭✭
I am using a Win10 Notebook to connect to my 6600 remotely. Using a USB headset. In testing using Win Sound Control panel and other apps on the notebook, the mic on the headset is working. But when using SSDR I get no RF out when transmitting.
- I have PC Audio and PC Mic selected.
- I am using the MOX button to key the mic. Tried using Vox but also does not work.
- Have read thru the archives but not found anything to solve my issue.
Has anyone else worked thru this problem and found a solution ??
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited November 2019
    Check the TX band settings panel, see that you TX is selected for the band your working.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Is the USB Headset your default Windows sound devices?
  • W2ECK
    W2ECK Member ✭✭✭
    Yes the headset is now set to default device on the notebook - but still not working
    tnx & 73
    paul w2eck
  • W2ECK
    W2ECK Member ✭✭✭
    Bill - hadn't thought about the TX Band settings on the SSDR install on the laptop. No none of the boxes were checked. Which column should be selected for the USB mic?
    73 Paul w2eck
  • WX7Y
    WX7Y Member ✭✭✭✭
    PC audio for RX and PC for MIC
    Make sure in Windows sound manager you can see on the MIC settings audio on the bar when you talk on the headset MIC
    Bret
    WX7Y
  • W2ECK
    W2ECK Member ✭✭✭
    Bret - I do see movement on the USB mic Vu meter bar in the Windows Sound Control Panel,   when I key Tx  using MOX.  But not seeing any movement on the RF Power meter.
    73 Paul
    w2eck
  • WX7Y
    WX7Y Member ✭✭✭✭
    Do you have DAX turned OFF Remote PC mic audio will not work if DAX is enabled
  • W2ECK
    W2ECK Member ✭✭✭
    Bret - Bingo, that was the fix. Turned off DAX on notebook SSDR and now the the USB headset mic is working. Thank you very much. I believe I did see then in one of the archived postings but it didn't relate at the time.
    Tnx agn & 73
    Paul
    w2eck
